MonkeyMan said:
Have any of you had problems with saved games in dead rising?
I have it as a rental at the moment and did a little bit this morning, but now I can't load it.
I definitely saved it as I can see my status, I just can't select the save it just has new game.
Am I missing something obvious here?
yes, this is the fabled save bug.
Its not a bug tho, just a wierd system.
Basically the game is meant to be played through a few times, like 100's not once or twice. Your sposed to be able to quit out when it gets too hard, or else just die. But of course you keep your stats.
Breaks down like this. If you die you get the option to save your char or load a previous save. If you save then your back to the main menu and free to start the game with your newly levelled up char. If you save in game you have 2 main options.
Save and continue
Save and Quit
Problem is in the wording. Save and quit ACTUALLY MEANS SAVE AN QUIT. As in save your stats and quit the game NOT save your position and come back later. Save and continue puts you back in the game, THEN if you quit you can load it but thats the only way.
Its a wierd system but when u truly understand the game it does make sense.
Edit: additionally to that, the reason the game is laid out like this is because you cannot do everything at the start, as level 1-10 there is no way your gonna save hardly any hostages and you'll probably get your butt kicked by most psychopaths. By level 10-20 you can probably make some headway into the story and save a few hostages and kill some psychos but you will die at times. By level 20-40 you can (depending on your skill) reasonably tackle the main story and choose to take on any side missions you like. Some bits are tough but north of level 30 you should cope. At level 40-50 you can actually do what you want, the game is fairly easy at this point and you can really do whatever you feel like or go attack the dreaded survival mode!!
basically ive 'finished' the game 20+ times but ive hardly done any of the story or survivgor missions because im simply not good/experienced enough for them, tho ive just hit level 25 so i think im nearly ready
