Deafult Location
11 Jun 2005
Brighton
Currently on XP, the defualt save, open, download location etc is My Documents. Is it possible to change this as it would save time etc.
I want to set it to a location on my second hard drive.
Also, can you change where programs install defualt etc?
Thanks
Dave
You could change your "My Documents" location and then right click and check the properties of My Documents. Just change the "Target folder location" to whatever you want.
Not sure how to change default target folder when installing programs. Not 100% sure it's possible.
