- 2 Nov 2004
Got blisters on my feet and I don't want them to get in the way of running, walking or dancing (should I choose to dance)...
What can I do about them?
$loth said:Doesn't this come under medical![]()
Ripper^ said:i posted a thread on blisters a couple of weeks ago. I've solved mine by buying proper running socks from JJB. Recommend you do the same![]()
squiffy said:![]()
Chop your foot off. It's the only way to be sure![]()
greenlizard0 said:Kind of extreme I suppose....
You can get cushion plasters which may help when you put weight onto those sore spots.
Defcon5 said:Put tape over the plasters and do a short run
cleanbluesky said:Okay, got some blister plasters on them. The question is, should I put thick socks on and go for a run tomorrow, or wait until the blisters are gone?
