- 15 Feb 2006
- hell
Hi guys,
I'm building a site at the moment that has a mysql table containing rows of data with 3 columns: id, name, url. The ID field is set to auto-increment in this case.
On my webpage I'm trying to pull out 5 random entries from the database, and print some text to a page. I've built some code to generate 5 random numbers between 1 and the maximum amount of rows in the table. But there's a problem here, if someone deletes one of the records...
Let's say I have 3 rows:
1 armyofharmony www.armyofharmony.com
2 overclockers www.overclockers.co.uk
3 bbc www.bbc.co.uk
If I delete record 2 (overclockers) and try and pick random entries from here, the table will look like this:
3 bbc www.bbc.co.uk
If my code then picks the number "2" and I query the database for sites with ID == 2 it won't work.
I figure I need to do my selection based on row number, instead of unique ID. From what i've googled this might not be the best approach.
Can anyone help me with this?
What's annoying is that I think I'm only suffering here because I'm using random IDs. If I just had to continually loop through 5 times I wouldn't need to care about the ID.
I'm picking the ID in advance using PHP so that the process is quicker than selecting it using mySQL.
Cheers
3 bbc www.bbc.co.uk
3 bbc www.bbc.co.uk
Cheers
