** Deals on XSPC GPU Blocks **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
we have some great deals today on the XSPC GPU Block range.
with massive savings to be made, we only have limited stock of each line so get in quick for some serious watercooling performance for your GPU
XSPC Razor GTX580 GPU Waterblock **Also Supports GTX 570** @ £65.99 inc VAT
Full Cover VGA Water-Block
- CNC machined copper base
- 1mm fins for high performance
- CNC cut stainless steel top
- Dimensions 170 x 124 x 9mm (19mm at ports)
- Prepared for SLI with 4 G1/4? ports
- Supports Nvidia GTX580 and GTX570 cards
(Nvidia reference design only)
Supplied with mounting kit, thermal pads and thermal paste
Was £75.00 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
XSPC Razor HD6970 GPU Waterblock **Also Supports HD6950** @ £65.99 inc VAT
- Dimensions 160 x 120 x 9mm (20mm at ports)
- Prepared for crossfire with 4 G1/4? ports
- Supports ATI 6970 cards
- Supports ATI 6950 cards
(ATI reference design only)
Was £75.00 Inc. VAT
ORDER NOW
Should blatantly do nickel plexi :)
Would have bought one if they were, apparently these have better temps than EK blocks?
so I hear.
the manufacturing process and design of this block is very different to the EK 'sandwich' approach that allows them to use clear tops.
also, these are very slim allowing for great flexibility in multi GPU systems.
