Deathadder double clicking issue
13 Aug 2012
I brought the Razer deathadder back last September but it starting to double click on a single click, what can be done about this?
I've tried adjusting the options in control panel to no use.
My friend had the same issue.
He gave me the mouse to see if I could fix it, and I just gave it a light tap, and it now works fine.
a slight tap in what way
Turn upside down, smack onto desk. Try.
Do note that I didn't care if i damaged it...
Come to think of it though. When I got home, it was the first time I plugged it into my PC so all the drivers started installing. Maybe, it's a software issue?
Try re installing everything?
My mouse has been doing this recently, noticed blowing inside it temporarily fixed it. Took it apart and blasted the innards with contact cleaner spray and it is now working again fine. Dust/gunk build up in the switches I am guessing.
