Don't touch any of those sensitivity settings!! Just set it to the middle setting in windows mouse settings with acceleration unticked![]()
Shame mine now double clicks the majority of the time and doesn't stay held down for dragging stuff etc
Set DPI and polling rate to the highest and lower the sensitivity slider until you feel comfortable, you have to give it a chance and get used to the higher sensitivity too, shouldn't take long.
That's mine but obviously you can't use those yet![]()
If it's double clicking when you single click then you need to update the firmware.
All the sliders Im same as rifleman, (note ADVANCED senstaivy x and y have those at 10 no matter what as your get the software screwing with your inputs else.) make sure windows is set to 6 for 1:1 inputs also
I use a polling of 500mhz the laser cannot do 1000hz consistent(from the info i have read, I could be proved wrong on this one),(if your usure what this does forgive my bad english but its update time on the laser.)
AFAIK the laser in the deathadder cannot hit 1000hz so you end up with figures like 990hz, 660hz 770hz 654 hz
And I find 1800dpi to be the best dpi on the deathadder. bf3 I play using 450dpi theres reasons for this, but thats another story.
Anotehr thing you may not no the double click slider, does nothing in games its not going to make you fire a 9mm any faster, again AFIK it only effects the desktop environment.
It's not a laser but I did hear this too, couldn't find any concrete evidence on it though so I've left it the same.AFAIK the laser in the deathadder cannot hit 1000hz so you end up with figures like 990hz, 660hz 770hz 654 hz
Nope that doesn't work anymore. I dropped it a few weeks ago and that fixed it for a while, now its back. It's intermittent though, like yesterday it wasn't bad at all. **** knows what's going on.
