Deathadder not 'detected' by Razer driver!
30 Dec 2008
SCOTLAND
My mouse is not 'detected' by the (Latest) Razer deathadder driver so i am unable to tweak the settings.
The mouse still works, All buttons still work. I usually have the Razer flashing logo switched off but now i can't!
Tried all the USB ports too.
Anyone any idea's what's happened ?
Go into device manager, find the mouse, right click uninstall then restart the pc using your keyboard... should reinstall it correctly..
BUT uninstall the driver first
install from driver disc with mouse unplugged untill it asks for it i think u have to do with the razer software wont always register if its allready plugged in i seem to rememebr or is it the other way round ? try both am at work atm so cant check mine but it happened to me a few times before it picked it up and had to do one or the other
