Decent 4890
31 Oct 2006
Uttoxeter
Ok.
Out of the ones on OCUK site, what really is the difference in them?
Just the makes? I mean i can see some have a slightly higher numbers, but is that about it?
Thanks
They are all pretty similar based on the same reference design, look for ones with the longest warranties and if they have added games etc. Also check the reviews for issues like "sounds like an aircraft taking off all the time" or "whisper quiet". All are DDR5 memory and the only difference is the core clock has been tweaked a bit more in the factory on some.
XFX- has the life warrenty and you can sell your card to some one and they will have warrenty as well
ASUS- had a very good voerclocking program that comes with the card on the cd (i have not used it my self)
other bards- as are as i know are all using the refernce cooler and come with the same things
