Decent android headset
18 Oct 2002
milton keynes
Looking for a android headset for our campervan.Tried a joying one that was nice but the physical buttons did not work so returned it. Looked at the dynavin one
https://www.car-vision.co.uk/citroe...dvd-cd-usb-fm-dab-headunit-5060431020317.html
But would like a pure android one . The cheap ones do not get good reviews and the alpine ect ones are very restricted. Budget up to £600.
Does anyone have a better idea?
if you liked the joying one why not get a replacement with hopefully working buttons? if you're looking for a "Factory" fit headunit then you'll struggle to find anything from non chinese manufacturer and all of them run pretty much the same "car" android OS/ROM.
Purchased it from joying eu https://www.joyingauto.eu/ But when i had a problem it took a long time and a lot of emails and sending video of it not working + £20 cost of sending it back to china but I did get the refund in the end.
If I could get it from a UK seller other than ebay I would.
Have you checked out the rainforest? They seem to be available on there, and some have good reviews like this one. Plus if anything goes wrong you should have an easier time dealing with returns and whatnot..
Just fitted this
Only problem so far is that the DAB antenna is a different diameter.
