Decent Car phone holder
9 Jul 2003
Perhaps I just got a bad one, reviews stated it could hold an iPad but it couldn't hold my m8 or a friends iPhone 6.
Orientation comment was regarding the pic above, plus pics from Amazon reviews showing the majority holding the phone portrait. Landscape just seems so much nicer.
20 May 2010
Englishman in the USA
I have a Spigen Kuel CD mount holder. The thumbscrew got in the way so I had to swap that out but other than that it's great. I have the one that grips the phone, not the magnetic one. It's £11 on the rainforest shop
OP
22 Feb 2014
Thanks guys, I've just ordered an Aukey magnetic. I did try one of the cheaper magnetic ones but like Monkeyman i think I went to cheap and it wasn't capable of doing its job.
9 Jul 2003
Let us know how it compares, I liked the idea but the one I tried (Wuteku) was rubbish. Slightest knock from the side and it would go flying :o
30 Sep 2003
Norwich
I use a CD player mount in my work car. Like others I never use CD's anyway. I prefer it to my Airframe clone as it allows me to still use all my vents and the phone itself is in a better position.
Just bought a cheap magnetic one from ebay for the MX5 as propping it up in front of the speedo is only fine as long as I accelerate at glacial rates. TBH looking at it it may well be a case of buy cheap buy twice but I'll give it a go.
Caporegime
24 Oct 2012
Godalming
I've been using a Spigen Stealth for about 6 months now, best phone holder I've ever used. It doesn't "stick" to the dash as such, it has a non-slip, slightly adhesive pad on the bottom to stop it sliding around and when I'm not using it I simply take it off the dash and fling it in the door pocket. When the pad loses it's stickiness, I simply wipe it clean and it's good to go for a couple of months again.
21 Jul 2008
Plus am I the only one that wants the phone held in landscape? :p
No. I also think it just looks strange in portrait mode.
EDIT: I will also ask though. Am I the only one who just leaves their phone in their pocket when driving? I mean, it connects fine to bluetooth when I turn the car on, and can answer it fine from the headunit.
Man of Honour
17 Oct 2002
Nope, me too. Phone stays in pocket or centre console. I don't want it stick on my dash in some sort of crap looking holder and I don' really want anything to do with the phone whilst driving beyond perhaps taking the occasional call over Bluetooth.
21 Jul 2008
Yes. I was sure there were gonna be a few things we could agree on, lol. I just don't get why anyone would want to see their phones sitting on display in their cars. It's not for me at all. I only used to put it in the centre console on the 5 series when I was using that eco pro analyser.
Having looked at all the suggestions so far though, I would probably go for that Spigen Stealth if I ever did want something. It looks like the least permanent, best secured solution.
18 Oct 2012
me 3, it's not as much about the looks, but mainly taking it out of ones pocket every time is just unnecessary faff when i can just hop in and go and music etc just connects.
fortunately, a 3 series ash tray also doubles as a near perfect place to set a phone on such occasions as i feel i need to, otherwise if its just for charging it goes in the centre console as thats where the charger is.
13 Apr 2013
La France
I currently have a reasonable car phone holder but it is the kind with a "sucker" on it and occasionally when it gets hot it "unsucks" itself.
Also it is stuck on to a sticky pad which mounts on the dashboard, which is total rubbish.
I've put up with this setup now for quite some time but its time for a change.
I am probably 1 of a very select group of people who are totally ok with permanently fixing something to the dashboard with screws, my mondeo is 14 years old I am not bothered about a couple of screw holes in the dash when it comes time to sell/scrap.
What can you recommend ?
https://www.ram-mount.co.uk/?gclid=EAIaIQobChMI5OnEvovj1QIV47ztCh24wgLfEAAYASAAEgL4VPD_BwE
Not the prettiest mounts you'll ever see, but they do exactly what the claim and are unbreakable.
15 Aug 2005
Glasgow
If you use your phone as a sat nav it's quite useful to be able to see the screen.
5 Apr 2009
Both my phones connect to Bluetooth happily in my pocket but the sat nav elements are somewhat harder to use whilst in my pocket :p
