Decent Closed Loop CPU Cooler?
29 Dec 2009
Was thinking about getting a H100 as I'd like more room in my case rather than the Phanteks pushing against the side.. Then I saw a few threads and heard nothing but complaints and issues about the pump.
So any other recommendations for a closed loop CPU cooler?
Or would I be better off spending another £50-£100 and going custom?
I've already took off the heat spreaders on my RAM and it still doesn't help. The Phanteks is just too large.
Any specific closed loop ones you'd recommend? As I hear nothing but issues with Corsair H-series.
I use a Kuler920.
Thicker rad than the 620/H60
Comes with two 120mm fans for push/pull, it also has a simple windows based software to tweak the Antec logo colour and fan speed.
