9 May 2013 at 14:52 #1 ballbern ballbern Associate Joined 21 Apr 2013 Posts 17 Could you guys recommend a decent CPU fan. Reliable, quite and good value for £.. Its for a AMD 6300 on a gigabyte 78lmt I've ordered.. Thanks..
9 May 2013 at 15:00 #2 DaleTheWhale DaleTheWhale Soldato Joined 17 Aug 2012 Posts 6,593 Location Tamworth, UK How much do you have to spend, do you have tall RAM?
9 May 2013 at 15:13 #3 Idleman Idleman Soldato Joined 14 Apr 2011 Posts 12,269 Location Newark Also, what case do you have? This will help us spec a cooler than will actually fit in your case.
9 May 2013 at 15:42 #4 ballbern ballbern Associate OP Joined 21 Apr 2013 Posts 17 The case is a cheap micro atx And the ram is standard as far as I know. Price. I just want something that does the job, nothing fancy..
9 May 2013 at 15:46 #5 Idleman Idleman Soldato Joined 14 Apr 2011 Posts 12,269 Location Newark This should fit(150mm H) and is a decent cooler for the price YOUR BASKET 1 x Thermalright Macho 120 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £29.99 Total : £34.98 (includes shipping : £4.16).
9 May 2013 at 15:46 #6 DaleTheWhale DaleTheWhale Soldato Joined 17 Aug 2012 Posts 6,593 Location Tamworth, UK I have a Ultra Performa Zalman heatsink, it's quiet and does a very good job. Paid £12 for it, but not sure what it is now. This is the model: Zalman CNPS8000B
9 May 2013 at 16:54 #7 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,908 Location N. Ireland you could go with the artic freezer pro rev 2?
9 May 2013 at 18:27 #8 doyll doyll Soldato Joined 1 Jul 2011 Posts 8,839 Macho 120 is a very good cooler.
