decent larger case/s
20 May 2009
Ok so i bought a tuniq 120 cooler and guess what? doesnt fit in my coolermaster elite 334....any ideas for a larger case?/ i dont want to send the cpu fan back because i have installed it already
also how far do you tighten this fan? it seems to slide around quite a bit even though it is screwed into place
What does my head in is the decent but cheaper larger cases all have LED fans. Which means having to replace them all if you wish to sleep at night with it on...
