decent low wattage PSU?
19 Aug 2005
Beds, UK
Hi all
I'm building an office pc for work, it will be a Pentium G4560 with an ITX mobo, couple of sticks of RAM, M.2SSD and thats about it.
so power requirements are low, but i still want good quality. so a good quality 350W PSU would be idea, but is there such a thing?
budget is whatever it needs to be really, but i dont want to over spend if i dont need to.
thanks
There is nothing wrong with getting a higher quality PSU that is rated for higher wattage output. The PSU will be more efficient and usually quieter since less heat is produced With that said, that doesn't mean buy a 1000W PSU for a 250W system.
Depending on your budget and what features you want, a TX550M would work fine, if not an RM550X if you want to spring for fully modular, Japanese Capacitors, and a Zero RPM fan.
