- 11 May 2013
I was going to do what I did with my first build and go for a very cheap solution to case and PSU: Coolermaster Elite 330U + Coolermaster 500W PSU bundle. But when I mentioned this on another board here it was suggested that the PSU is a bit rubbish and I should get something better.
Problem is that throws my budget out as I'd earmarked no more than £60 (inc. delivery), preferably less, for this part of the build and I really can't stretch it any further.
If power requirement calculators are to be relied on a 400W PSU would be OK but a 500W better.
I have nothing against the Coolermaster case mentioned, it has been used by plenty of pro PC builders in the past and the general build quality is fine. BUT it has one not so good feature:the main on/off button is flimsy.
Some reviews mentioned this but I ignored it and it has been worrying me ever since. I have read a couple of later user reviews where the button, which apparently uses a plastic spring, has broken rendering the whole otherwise decent case unusable as it can't be reliably repaired or replaced.
I was looking at some cheap cases last week and in comparison to the Coolermaster they were made of what seemed little more than tin foil. So is there any better made midi-case/PSU solution at <£60?
my favourite choice is the Corsair Carbide 200R. Plain but well made and a professional looking piece of kit.
