Decent monitor for PS4 Pro
2 Dec 2004
Under The Desk, Wales
Getting a PS4 Pro so need a decent monitor to use with it. I say monitor because i will be using the monitor for a pc i am going to build next year. Then, i will buy a big TV for the PS4 Pro. Cant do that at the mo as living in a bed sit.
Will need a decent wall arm to mount the monitor on too.
Any ideas. Budget i guess around £200 for the monitor. I will be watching movies on it too off of the PS4 Pro.
Do you want 4K? If so, you're going to be hard pressed to find a good one for £200. This is probably cheapest...
https://www.overclockers.co.uk/asus...g-widescreen-led-monitor-black-mo-09j-as.html
But consider for the future, when building a PC, that you'll need a beefy GPU to run at 4K. Plus with Freesync that would suggest the AMD route. They don't currently have a GPU that can push 4K very well, but maybe next year they will have something.
Thanks. Picked up a 27" Acer today. HD, 1ms. Freesync Will be perfect when i build my pc in Jan.
