- 27 Apr 2004
Background:
A fairly long bungalow wired with Cat 6 in most rooms that has a pair of ZyXEL G-1000 access points, one at each end of the building.
The problem with the current setup is that the users that have devices that actually use the wireless network (a pair of Dell laptops and a pair of HTC Hero phones) report that the wireless network fails on a regular basis and that they are able to get it working again by restarting the access points.
This makes me suspect that the best course of action will be to replace the access points (since replacing the laptops/phones is not an option anyway).
As such I'd like a couple of recommendations for access points to buy as a pair and replace the existing ones with. Ideally they should be wireless N capable with decent G backward compatibility. If they are N capable I imagine it would make sense for them to each have a Gigabit connection (though the current switch is only 10/100, it makes sense to future proof).
Commercial grade kit I imagine may provide the reliability required, so anything up to £100 per access point I'd like to hear about - but don't let that stop suggestions for cheaper access points too!
Thanks,
Mr. Brightside
Thanks,
Mr. Brightside
