I currently have a 560 Ti in my Sugo SG05 case and want to upgrade but am finding it difficult to get a card that is shorter than 10 inches. Any suggestions?
I have the MSI GTX 760 Twin Frozr Gaming in my SG05 which is 260mm long. Anything longer will not fit without removing part of the front panel with a dremel
The GTX 770 (Twin Frozr) is also 260mm long if you want something more powerful but don't want to cut the case
If you have PCI-E power connectors on the top of the card then you can just about squeeze in a 10" card. Cutting a hole in the case gives you another 3/4" and the plastic facia will still cover the hole.
