Decent replacement for Sky FTTP router…
31 Aug 2007
As title, anyone know of a decent replacement for the Sky FTTP router? It’s been nothing but a nuisance lately. If I have a power outage, the router simply refuses to connect until I remove the power lead from the wall for 2 minutes then reconnect it. Even then it takes an age to reset itself. If I’m away from home when there’s an outage, obviously I wouldn’t be able to do this.
I also find the WiFi coverage to be average at best. I’ve installed a 4 disc BT Whole Home Mini set to work around this, but it’s not ideal really, as I also have a couple of smart devices that refuse to work with the merged 2.4 and 5 channels of the BT discs, so I’ve also had to install 2 Netgear boosters which I have set to 2.4 only. It’s maybe a tad clumsy but it just about works.
I’m therefore wondering if there’s something I can completely replace the Sky router with? Anyone know of something that will do what I need and be a lot more reliable than the Sky rubbish? Thanks
I use a TP link archer AX11000 tri band gaming router, and AX1800 one mesh wi fi extender.
I’ve never even plugged the sky router in and I have no problem with good speeds in the garden.
they are not cheap but worth it in my opinion.
Thank you! So, can you confirm this connected straight to the Openreach box on the wall and logged you in with no issues etc? Sounds like a great option if that’s the case, the Sky one really is garbage
Is the router really garbage or is the wifi side of things the problem? Chances are the routing side of the Sky box is absolutely fine.
I'd be looking to keep the Sky router and offload the wifi role onto a dedicated wireless access point rather than dropping £350(!) on a "gaming" router that made me feel a little bit sick every time I saw it. I like Ubiquiti access points, but there's plenty of choice.
The main things with it are the WiFi coverage isn’t good (I have that resolved by using BT Whole Home discs for my WiFi) and also the fact that it simply does not recover any time it loses power. My area suffers from an odd power outage now and then and it’s a real nuisance that the Sky router insists on being completely unplugged from the mains for a couple of minutes before it starts operating again. Without doing this almost none of the lights on the box are lit.
I’m not bothered too much about costs to replace it, but yeah I would agree I don’t need an expensive gaming router, I just need something that’s reliable. I’m not even overly fussed about the WiFi coverage because I have that mostly sorted, that said it would be good if the replacement had decent WiFi as it would at least give me more options.
And a £300-400 router is no sledgehammer? :p
Tbh a decent UPS is like £100 odd, if you have frequent power cuts (presuming they are very short) I'd genuinely recommend one. Connect up your router/modem/PC and anything else important you like.
Look up the APC BE850G2-UK for around £112.
Thanks again for all the suggestions guys. The UPS is actually maybe not a bad call (power outages are usually only several seconds long), as is contacting Sky and asking them to replace it. I’m going to call them in the morning and see what they say.
Yes it’s connected straight into the ont. You need to change the settings in the router but it’s pretty simple.
I had issue’s with the BT kit and got a great deal on the Archer and I have never looked back since, it’s been rock solid for a year and half using both BT and Sky Fttp But is expensive.
Excellent! Thanks again. It’s certainly expensive but I can keep an eye on it, definitely gives me an option.
UPS ideal then, you'll never notice it even happened then. :D
And dear god it is absolutely hideous! I could only have one if it lived in a cupboard! The design looks like something that would have been stuck on a 1l Corsa in a 90’s copy on MaxPower magazine!
Can you help me and share the settings you used? Just flipped to sky on a deal and my AX11000 aint liking the change!
