Decent RGB Scart Switcher
6 Jul 2005
Hi there,
Just ordered some new RGB cables to from Sky+ and the DVD Player to the TV. However my TV only has 1 RGB Scart socket. So could someone recommend a decent switcher for around £20? Ideally it needs to automatically switch.
Many thanks,
Mike
Plug the DVD player into the Sky+'s "VCR" scart socket and then the Sky+ box to the TV.
I would be suprised if you see a difference with the new cables.
I assume your TV is a few years old/not massive if it has only one scart socket.
I think he means it only has 1 RGB scart Tesla.
Ahh missed those letters.
If it does have more than one scart socket then perhaps the second or third accepts SVideo? Does your DVD output Svideo via scart?
Yeah the tv has 3 scarts, but only 1 is RGB. It's a 51" Sony RPTV.
Thing is, only 1 of the scarts on the sky+ box is RGB...
Edit: Yeah the 3rd scart on the TV can do S-Video. Not sure about the dvd outputting it via scart though.
Just get an el-cheapo scart doubler mate. They are fully wired and will pass the 2 devices into the TV no worries. I did the same on my sony RPTV.
It's not needed though.
You;re correct about Sky+. Only the TV scart will output RGB but VCR will input RGB and loop it through to the TV out.
I would plug the DVD into the SVideo scart and set the DVD player to SVideo.
That way, you can connect a recorder to the sky if need be at a later date.
S-video looks really poor on these sets though mate :( RGB shifts the TV into a different mode and looks completely different.
If the sky+ box will loop the RGB feed from the DVD then do it that way. Failing that the scart doubler will effectively give you 2 RGB scarts on the TV which will be useful.
Didn't realise that with regards to SVid/RGB.
Sometimes you get feedback problems with the splitters though. Apparently Argos sale a cheap one which is supposedly rather good.
The Sky+ loop through method is free but as Jez says, having an extra RGB socket could be handy.
Sure you're using a scart socket that takes an s-video input, and that you've selected s-video input for that socket via the tv's menu? S-video doesn't look as good as RGB it's true, but it shouldn't be far off.
Yes, i'm sure ;)
