Hi There,
My friend is with Plusnet Fibre for internet, but they're having a problem with their wifi.
Connect in with a cable and the speeds are very good (65mbit:line speed!) - however with wireless the range is pretty dire and, when even within range, they can only get around 15-20mbit on the wifi.
I've scanned around using InSSIDer and the Wifi Scanner on my android phone. Found that nothing else is using their channel (1). Channel 11 is also clear - moving to that made no difference, so have moved back to 1.
So to improve this, what should we get? A standalone access point to connect to the router (and therefore turn off the wifi on the existing router?) or just get a new router &make sure it's one that's got decent wireless built in.
In either case - what would you recommend?
Thanks,
Blueacid
Thanks,
Blueacid
