Decent tool kit
3 Jul 2008
Fife way up in Scotland
Im possative there has been threads on this one before but i cant see them.
I want to purchase a realy good tool kit for a pc, hopefully including a set of forceps and non magnetic screw drivers and in its own case
i cant find any i perticularly like the look of on a simple Google search.
Has anyone here bought one they have been impresed with.
Managed to grab one from a local high street electronics supplier, was about £15 iirc comes in a black case that folds out to reveal a number of items.
ITs done pretty much everything I needed but I did have to add the following myself:
Smaller Screwdrivers (for those annoyingly small screw sometimes used on mices/kb/screens)
Torch
Scissors
Safety Drivers
I cant link to the store as they are competitors but theyre pretty much the only highstreet Electronics/hobby store left
Sounds very similar to the belkin ones I use at work :) Theyr'e ok. Not what i'd go for if i was using it day in day out professionally. I'd buy separate screwdrivers, pliers etc and make my own kit. That way you know all the parts are quality.
I bought a cheap one off a competitor as there own brand one, and my dad bought a Belkin one, they are near identical, probably all come out the same factory!
It comes in a black zipped up case. I dont find you need much, couple of screwdriver, compartment box to hold spare screws and jumpers. A torch is useful I guess, and those little grabber things that can pick up screws.
Is that the ones with purple shirts?
I found one on the online shop thats named after a rainforest. its belkin 65 peice one. im not sure if i realy nood to spend allthat much as i only use it for building the od pc and upgrades but would preffer to have decent kit that wont destroy anything in my system
