Decent upgrade from a 6800XT?
2 Jan 2004
Chesterfield
I've got a bit of an upgrade itch and am wondering what a decent upgrade from my 6800XT would be?
I game at 1440p and the rest of my specs are in my sig.
Ideally a quiet GPU too!
Not sure there really is at the moment. I upgraded from a 6800 to a 7900GRE which gave me a decent uplift and a decent RT amount as well although not comparable to 4000 series Nvidia cards. I am happy as I really wanted a sapphire nitro. If I were you I would wait for RDNA 4 or possibly a reduced price 4080 super if it comes up.
Best to wait for more news on RDNA 4, unless you have a lot of cash to burn. E.g. 7800 XT is barely any faster than what you have.
Yea I wouldn't bother either mate.
Unless you are properly minted or the money isn't a factor then sure, whatever, otherwise I don't think it's worth it.
Is this a worthwhile upgrade? A quick Google (albeit only on of these benchmark score websites) would seem to suggest not much of a difference between my 5600X and a 5700X3D??
Depends on the game/software/resolution, the 5700x3d has 2 extra cores and extra L3.
Truth be told I'm not exactly struggling to run anything I'm playing - the (I assume) GPU fans could stand to be a bit quieter but other than that I'd be just ust upgrading for the sake of it!
Wait until there's solid news for next round of GPUs unless there's a game that's bothering you but then you'll have to spend to get a significant upgrade.
May as well wait for RDNA4 if you're not struggling to run anything, unless you want to fork out £800+ for ~4080 performance, which is absolutely not worth it.
