Decent used wheel?
17 Jun 2012
I'm looking to try a wheel for a few games I'm tempted by like Dirt Rally and Pcars, what is a decent used buy?
I don't want to splash out on a new expensive one in case I don't get on with it, I've seen a Logitech Driving Force GT locally for about £50, is that worth a punt?
If u can deal with the excessively loud "whirr whirr" noise from the ffb motor when in use, then yes its a good starting wheel. 5/10 imo
However they feel heavy and slow compared to a g27, 8/10 imo.
I own them both, and the dfgt is modded with the ffb motor swap, but even after the mod I would never use it over my 27
Is it worth a £50 punt? Id say so, as Im sure your could pass it on for the same if you dont like it.
Problem with the G27 is it's used value, it's way over what I want to spend on something I just want to try out, plus if I don't get on with it for whatever reason then I'd have to sell it on and I just don't have the time (or bothered with the hassle) of moving something like that on.
