Hoping I can get some help of the watercooling wizards here.
I currently have a bigwater SE kit and although it has served its purpose by keeping my OC'd opty moderately cool, with summer now in full force I am now looking to get some 'proper' kit. I am only looking at cooling the CPU as the 7800GTX 512mb cooler is quiet enough even when overclocked. Money is tight so I am still doing it on a budget (apx £150) and I have narrowed it down to a couple of options.
1. Swiftech Apex Ultra £160
or
2. Custom kit -
AlphaCool NexXxoS XP
AlphaCool NexXxoS Pro II Radiator
AlphaCool Cape Coolplex 25 external
AlphaCool AP700 Centrifugal pump 12V
Connections & Hoses (10mm)
Total £114
I know the weak link in the custom kit is the pump (700lph) but if I upgrade to a laing then that will send me over my budget. Will that pump be enough to run that loop adequately? I would like a 360 rad but I feel that would be putting too much pressure on the pump. The position of the rad isn't a problem as it will be externally placed on my windowsill.
I have also read that 3/8 tubing is just as efficient as 1/2 but easier to route therefore a better option. Does the Apex kit come with 1/2 tubing?
I suppose what I'm really after is 'which kit would be better'.
Thx in advance.
or
2. Custom kit -
Total £114
Thx in advance.
