CPU Block: Swiftech Apogee
Northbridge Block: Alphacool NexXxos NBXS-N
Voltage Converters: Alphacool (for ASUS boards)
GPU Blocks: x2 Swiftech MCW60
Pump: Laing D4
Tubing: Swiftech Smartcoil UV Blue
Reservoir: XSPC 250mm Passive - Blue
Radiator: Alphacool Black Ice Pro 240mm Radiator
Fans (Radiator): x2 Vantec Stealth 120mm
decided i need to cool voltage converters behind CPU socket as well as northbridge, the heatpipe is great idea but its a bit well, rubbish plus if im gonna go for the full watercooling then why not
as well do you think all of the above will fit inside of a Thermaltake Aguila case? thanks on any input
Pump: Laing D4
