decided on my build, open to advice.
21 Jun 2014
before i get slandered for bottlenecking i got the gfx for cheap so it was a choice well made.
i currently have:
amd radeon r9 290 4gb gddr5
Corsair 8GB (2x4GB) Dual Channel Vengeance DDR3 1600mhz
AMD FX 8350 4.0 GHz Eight Core processor
going to get:
ASRock 990FX Extreme3 AMD 990FX (Socket AM3+) DDR3 ATX Motherboard
650W Corsair HX, Hybrid Modular, 80PLUS Gold, 1x140mm, ATX, PSU
Asus 24x DVD±RW DRW-24F1ST SATA ReWriter
Microsoft Windows 7 Professional 64 Bit SP1 Full Version
aerocool predator x1
WESTERN DIGITAL 1TB 3.5" INTERNAL SATA HARD DRIVE
if you have any suggestions for changes to the "going to get" section let me know! i get the feeling theres probly a better motherboard i could get for the same price
hmm 1 worrying review on there, what about this? SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black
lee i got the corsair as advised ubt it came with an american plug socket if i use a uk 1 instead will it still work? my friend told me that it would blow my system because american wall voltages are lower than uk wall voltages.. dunoo if its true or not, hope its not >_<
Most modern PSU like the Corsair are auto switch over.
Older / cheaper models had a switch which you manually moved.
AWESOME! know anywhere that sells them cheap? just need a 12v 5a and the lowest there was is £12 on ebay >_>"
Chop the plug off and wire a UK one on ?
Are you sure it's not a European style plug ? It seems a bit odd that a psu sold in the uk would have a USA plug on it.
sorry rj wasnt checking the comments, wouldve removed it if id of known sooner but cheers il buy the cable now c:
No probs :)
is shipping just the packaging of the product or the delivery as well?
Shipping is the final price, includes packing and shipment costs, due to the Insomnia event they have changed the default shipping info at the checkout, I need to log in to see the shipping / packing costs for those who don't get free shipping.
