Howdy,
After a discussion on a previous thread I have decided to upgrade my stock VGA cooler on my BFG 7800GTX OC 256 with a Zalman VF700-CU Quiet Copper VGA Cooler.
I'm gonna order this in a bit, but I want to order it with a CPU cooler as I think the stock AMD one is a bit noisy. So what CPU cooler would you recommend for my AMD Athlon 64 X2 Dual Core 4400+ - Socket 939?
I'm not a heavy gamer, I simply use windows for everyday stuff... so the main priority of the cooler is for it to be quiet... but hopefully keep it a bit cooler than the stock AMD jobbie?
Any help appreicated!
thanks
thanks
