Decided to upgrade my PC
17 Aug 2007
Maidenhead
Asrock ALiveSATA2-GLAN (Socket AM2)
PCI-Express DDR2 Motherboard OC Stock Code: MB-017-AK
AMD Athlon 64 X2 Dual Core 4200+ 2.20GHz
(Socket AM2) - Retail Stock Code: OC CP-168-AM
Arctic Ceramique Thermal Compound (2.7g) OC Stock Code: OA-004-AC
Crucial 2GB (2x1GB) DDR2 PC2-4200C4 Dual Channel Kit
(CT2KIT12864AA53E) OC Stock Code: MY-082-CR
Asus GeForce 8600 GT 256MB GDDR3 HDTV/Dual DVI
(PCI-Express) - Retail Stock Code: Stock Code: GX-128-AS
LiteON LH-20A1P-487C 20x DVD±RW x12 Ram
Dual Layer DVD-Writer - Retail Stock Code: CD-064-LO
Seagate Barracuda 7200.10 160GB ST3160815A ATA-100 8MB
Cache - OEM. OC Stock Code: HD-099-SE
Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk
(N09-01528) OC Stock Code: SW-034-MS
Is all this compatible?
Total Inc VAT and Delivery: Total: £374.68p
Any other thoughts?
Good choice of HDD but wouldnt it be worth getting Vista Basic instead of XP Home?
For future proofing and of course better security for your pc then Vista Basic would be far better.
With XP Home, to start with it will take you ages just downloading the updates and then of course Microsoft is phasing the selling of XP out by Q2 of next year and then support will not exist anymore come 2010.
Edit: Plus its the same price as XP Home :)
Sorry i did not mention it has media centre +Create high definition movies
with Windows Movie Maker in High Definition worth 8pounds in my book. :cool:
I've used Vista on my sister's PC, I can't stand it.. Anyway, some of my gamed wont work with Vista
Thats all fine. That will be a big upgrade over your old rig.
Only query is why get the Asus GeForce 8600 GT 256MB @ £91.64.
It may have DX10 support but it will run DX10 games at like 1-2 FPS.
So its really a DX9 card like the ATI card below.
When you can get the much better OcUK ATI Radeon X1950 Pro 256MB GDDR3 HDTV/DVI (PCI-Express) - Retail @ £72.84 inc VAT.
Edit. Yep, im using XP still as well. Dont see any reason to change to Vista.
Hmmm..
I’ll take it under advisement
