Decimator or Xenomorph?
2 Jul 2006
Cornwall
So, i've narrowed it down to these two pre-built systems which i'm interested in, both with the 460GTX.
However, I can't really decide which one to opt for. I must say, that the Decimator is the most appealing; 6 core processor with the potential to upgrade in the future and the obvious bonus of 4 more cores, but is it worth £70 more?
The build would be for gaming primarily, I know the i3 @ 4.2ghz would do the job nicely now, but i'm worried for the future as more games will utilise quad core, and 1156 is on it's way out, unlike AM3...
Help :(
If you can afford the extra 70 hell yes it's worth it.
AM3 socket + 6 cores = future proof. New AMD processors will use AM3 socket so it will be easier to upgrade.
The Decimator is an awesome system, the extra cores give it the edge over the Xenomorph but you pay the extra for it. Depends on your budget, if it isn't a tight one I would choose the Decimator.
