- 17 Jan 2006
Hi All
In the coming months I intend to build some decking at the end of my garden. At present there is a concrete base in place that the previous owners made (installed, poured, put down...or whatever the correct term would be) which is great except it is very ugly...
One side of the base is shaped round a raised planter made from old sleepers which I would like to keep in place as it is rather nice and I think will work quite nicely sort of spilling over to the decking once we have some plants in it.
Now, the planter is not hugely high which limits the height of the deck, though to be honest I also wouldn't want a high deck as my little boy (16 months) would most likely fall off it continuously!!!
I know most decks are made up of an exterior frame raised on posts with suspended joists hung between the frame however, my plan is to use 4x2 to make the frame which will be the outer frame and the joists all in one and be laid straight onto the concrete base rather than having any posts to rasie it at all as this way the height will fit in nicely with the planter and the height I want the deck.
I've tried googling for such a setup but most websites only tend to have info about constructing raised decks with post and suspended joists.
Would my plan be ok or are there any problems with doing it this way?
