- 13 Apr 2013
- La France
I have a decked area where the decking and the batons underneath are in reasonable shape, but many of the decking boards are loose as the tiny screws the installer used have snapped under load or pulled out.
As I can’t re-use the original holes, I’m currently changing bits in my cordless drill/screwdriver 3 times for each new screw I fit.
1. Pilot drill to stop batons splitting
2. Clearance drill for decking plank
3. Screwdriver bit to install new screw.
There must be a smarter way or tool I can use to do this that doesn’t involve my buying another 2 cordless drills.
