Permabanned
- 28 Dec 2009
- london
I am trying to decommission my first production DC. Its an old 2003 DC that has not been well maintained. I have already introduced a 2008 r2 sp1 DC in the forest and moved the roles over and complete the dc decommission checklist and tests found at:
http://technet.microsoft.com/en-us/library/cc755937(v=ws.10).aspx
At this point i have reached the dcpromo task and was expecting to uninstall the dc and have the job completed but it comes up with an error:
"Before you install or remove active directory, you must remove certificate services"
I can across this article that explains the process of removing the certificate authority from the dc:
http://support.microsoft.com/kb/889250/en-us
Now my question is: Would i not need to transfer this authority to another DC rather than just follow the instructions in the above article which basically stops and removes all certificates and uninstall's the certificate services?
Actually think i've just found the answer, http://technet.microsoft.com/en-us/library/ee126140(WS.10).aspx
Looks like the best solution is to rename the new DC to the same name as the old DC, to prevent having to reissue all the certs.
http://windowsitpro.com/windows/moving-certificate-authority-ca-another-dc
Short guide to the point. But as a mistake could lead to all clients having cert issues i am a bit apprehensive about it and in no rush..
