Dedicated Box
10 Jul 2006
Brighton
Not sure if this is allowed, i do aplogize if its not.
I am looking for a UK based dedicated box which i can run gameservers on and have access via Remote Assistance.
My budget is say £70 per month and no setup fee if poss. I have found loads but im wondering if you guys new any that you may have used or been recommended?
Thanks,
B
Xtrm2Matt said:
www.webhostingtalk.com
Good place to look. Also a decent place to look at reviews of companies (highly recommend you do so before buying one).
What he said :)
If you're going dedicated, make sure you, or someone you know; is pretty hot with security. Unless the server is fully managed and the guys running it know how to keep a game server secure.
Jolt did have a server with loads of different game servers on it, and you just selected the ones you wanted - with the ability to swap and change as much as you like. Not sure if they still do it?
