Here are my findings going from On-board Network Card to Dedicated
My Network (50M from house to Cabin)
Machine under Test
i7 3770k @ 4.6Ghz
16GB 1600MHz
MSI Mpower Z77 Motherboard
7990
Most important
Onboard
LAN 10/100/1000 Fast Ethernet by Realtek® 8111E
Dedicated
Intel Gigabit PRO/1000 CT Desktop Adapter PCI-express
http://www.overclockers.co.uk/showproduct.php?prodid=NW-015-IN&groupid=46&catid=1597&subcat=1599
i have always wanted to test Onboard vs Dedicated but, never found a decent chance to. So now i do!
as my On-board would only reach 128mb/s from my Virgin connection but my laptop would reach 156mb/s! (difference Laptop has intel onboard!)
Steam downloads on onboard peaked at around 22/35 but would suddenly drop like it could not keep this up.
Time difference between tests Max 5-10 Minutes
Comparing Onboard to Dedicated
Test #1 - Measure Ping
Simple Ping Google.com
Onboard - 22ms Average (over 3 attempts)
Dedicated - 11ms (average over 3 Attempts)
Test #2 - TF2 max Server Ping
Used UKCS 32 man Full Server
Onboard - 57ms - (using Hl2 Console ping command) (3/3 attempts)
Dedicated - 37ms - (using Hl2 Console ping command) (3/3 attempts)
Test #3 Speed-Test
Using Namesco Server (tested each 3 times)
Onboard - 126mb/s down - 8mb up
Dedicated - 153mb/s down - 8.5mb up
You could say this could be Internet Fluctuations & indeed you are correct, But didn't have a good setup to test at the time. (Offline Only) So just used this. i'm Happy for £30 it did what i wanted. Not slowly down my throughput
Might Test Steam tonight
This thread is not to tell you if this is good or bad, just my findings. that is all.
Machine under Test
i7 3770k @ 4.6Ghz
16GB 1600MHz
7990
Most important
Onboard
Dedicated
Test #3 Speed-Test
