a dedicated VGA power supply which fits in a spare 5.25” bay and can be used to power a single VGA card, its main purpose is to give your system the extra energy to use SLI/Crossfire and so the X3 Booster has two 6-pin PCIe connectors.
There is no need to eliminate the original PSU you used. Just simply add the BOOSTERX 3 and it not only can work with your original system but also offer you the higher wattage in graphic performance.
Supplementary Power Supply Unit
Essential for Dual VGA Cards System
Easy-Fit to 5.25 Drive Bay and Simple Installation
Active PFC (99%)
Ultra High Efficiency Design (>85%)
Dual 12V (Each Rail 150W), Individual Output
Maximum Output 300W (Peak Output 400W), Dual PCI-Express Output
Advanced Auto-Power-Recovery System (APRS)
Extremely Low Noise Design (<29dBA)
Improve System Stability
Blue LED-High-Gloss Black Front Panel
Front In-Take Dual Rifle Cooling Fan
Mesh-Wire Cable Management
Specifications
Full Range Input: 90~264Vac
Voltage: +12V
Current (Min.) : 2.0 A
Current (Max.) : 25.0 A
Regulation: +/-5%
Ripple & Noise: 150mV
Output Power: 300W
Maximum Support: 400W
Independent OVP/OCP/OTP
MTBF:50,000 hours
Hold up Time: 10ms at 230Vac
Dimension: 205x149x42 mm
>>> Click Here <<<
Active PFC (99%)
Specifications
Voltage: +12V
Regulation: +/-5%
Output Power: 300W
MTBF:50,000 hours
>>> Click Here <<<
and IMO a 580w Type R isnt efficient enough to run a well clocked setup with 2 X1900's...
. Works flawlessly on my 1900 crossfire setup and heat is a total non-issue as it is in a U2-UFO
. I got it for about £40 new so it was a no brainer to try imo
