- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
DeepCool Fiend Shark Ultra Quiet High End CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA77/AM2/AM2+/AM3) @ £64.99 inc VAT
This fiend is uniquely designed to achieve greater efficiency in both CPU and system cooling. The mammoth size of this cooler creates an amazing performance cooler for any beastly system.
- Equipped with multiple clips to support Intel LGA1366/1155/1156/775 and AMD AM3/AM2+/AM2
- 6 sintered powder heatpipes conduct heat from the processor quickly to protect it from overheating
- Nickle plated copper base gives perfect contact with the CPU surface
- Dense nickel plated aluminum fins with big surface dissipate heat efficiently
- 140mm PWM fan with TPE cover fan frame to absorb operating vibration and noise maximumly
- Cool the CPU and the surrounding components like Mainboard, memory card, chipset, etc
- 150W solution, a perfect choice for overclockers
- Fan Speed: 1400 RPM
- Air Flow: 71.8CFM
- Noise: 18.2 - 26.7dBA
Only £64.99 inc VAT.
ORDER NOW
DeepCool Ice Warrior Ultra Quiet CPU Cooler (LGA1366/LGA1155/LGA1156/LGA775/AM2/AM2+/AM3) @ £49.99 inc VAT
DeepCool's Ice Warrior heatsink ships with it's own special brand of rubber over moulded 120mm PWM fan. Additional wire fan brackets are supplied for users that wish to attach a second fan (not included) to the rear of the heatsink. The 155mm tall heatsink uses six 6mm diameter copper heatpipes to connect the copper base plate to the 114mm worth of aluminum cooling fins above. Each aluminum fin measures 0.4mm thick and is spaced 2.0mm from the next. The bottom-most fin is elevated 38mm above the base for motherboard clearance.
- Six sintered powder heatpipes conduct heat from the processor quickly to protect it from overheating
- Nickel plated copper base gives perfect contact with the CPU surface
- 120mm PWM fan offers a perfect balance between airflow and noise
- Uniquely designed fan made of special material, modding looking
- 48 pieces of aluminium fins with big surface dissipate heat efficiently
- De-vibration rubber fan cover absorb operating noise maximumly
- Intelligent side flow design further utilises system airflow to improve computer case ventilation
- Tool free installation
- Fan Speed: 500 - 1500 RPM
- Air Flow: 66.3 CFM
- Noise Level: 17.8 - 27.6dBA
Only £49.99 inc VAT.
ORDER NOW
DeepCool Ice Matrix 400 Ultra Quiet CPU Cooler (Socket LGA1366/1155/1156/775/AM3/AM2+/AM2) @ £39.98 inc VAT
Deepcool's Ice Matrix 400 is a great looking tower cooler that installs easily and comes with a quiet fan and a lot of handy accessories. With the option for a second fan to be installed installed, it's possible that the Ice Matrix 400 could be the ideal choice in the performance cooling arena.
- Four sintered powder heatpipes conduct heat from the processor quickly to protect it from overheating
- Heatpipes are lined up in a straight line to improve air flow through the heatsink
- Dense anodized aluminium fins with big surface dissipate heat efficiently
- 120mm PWM fan with TPE cover fan frame to absorb operating vibration and noise
- Intelligent side flow design further utilizes system airflow to improve computer case ventilation
- Air Flow: 66.3CFM
- Noise Levels: 17.8 - 27.6dBA
Only £39.98 inc VAT.
ORDER NOW
DeepCool Ice Edge 400-FS Ultra Quiet CPU Cooler (Socket LGA1366/1155/1156/775 and AMD AM3/AM2+/AM2/K8) @ £24.98 inc VAT
This entry level aftermarket cooling is great if you are looking for a high performance cooler with a limited budget in mind. Offering a mirror polished copper base and 4 heatpipes you can happily overclock your PC without the fear of meltdown when using this cooler.
- Equipped with multiple clips to support Intel LGA1366/1155/1156/775 and AMD AM3/AM2+/AM2/K8
- Mirror polished copper base gives perfect contact with the CPU surface
- 92mm fan offers a perfect balance between airflow and noise
- TPE Fan Cover helps absorb operating vibration and reduce fan noise
- Fan Speed: 2000RPM
- Air Flow: 36.16CFM
- Noise Levels: 26.3dBA
Only £24.98 inc VAT.
ORDER NOW
DeepCool UF-140 Ultra Silent 140mm Fan with Anti-vibration TPE Cover @ £14.99 inc VAT
- Strong plastic frame with soft and elastic TPE cover to absorb vibrations
- Special fan blade design to offer a unique visual effect when operating
- Two ball bearing to offer smooth rotation and long lifetime
- Super silent and big airflow
- Overall Dimension: 140 x 140 x 26mm
- Net Weight: 167g
- Bearing Type: Ball Bearing
- Rated Voltage: 12 VDC
- Operating Voltage:10.8 to 13.2 VDC
- Started Voltage: 7 VDC
- Rated Current: 0.13 ±10% A (MAX)
- Power Input: 1.56W
- Fan Speed: 700 RPM ±200 to 1200 ±10%
- Max Air Flow: 71.8 CFM
- Noise Level: 17.6 to 26.7 dB(A)
- Warranty: 24 months
- EAN barcode: 6933412704164
Only £14.99 inc VAT.
ORDER NOW
DeepCool UF-120 Ultra Silent 120mm Fan with Anti-vibration TPE Cover @ £12.98 inc VAT
- Overall Dimension: 120 x 120 x 26mm
- Net Weight: 172g
- Operating Voltage: 10.8 to 13.2 VDC
- Fan Speed: 500 RPM ±200 to 1500 ±10%
- Max Air Flow: 66.3 CFM
- Noise Level: 17.6 to 27.8 dB(A)
- EAN barcode: 6933412704157
Only £12.98 inc VAT.
ORDER NOW
DeepCool UF-80 Ultra Silent 80mm Fan with Anti-vibration TPE Cover @ £10.99 inc VAT
- Overall Dimension: 81 x 81 x 26mm
- Net Weight: 111g
- Rated Current: 0.07 ±10% A (MAX)
- Power Input: 0.84W
- Fan Speed: 900 RPM ±150 to 2200 ±10%
- Max Air Flow: 22.6 CFM
- Noise Level: 17.6 to 23.4 dB(A)
- EAN barcode: 6933412704171
Only £10.99 inc VAT.
ORDER NOW
Left to right Fiend Shark, Ice Warrior, Ice Matrix 400, Ice Edge 400-FS, Megahalems.
- Air Flow: 71.8CFM
ORDER NOW
ORDER NOW
- Air Flow: 66.3CFM
ORDER NOW
ORDER NOW
- Net Weight: 167g
ORDER NOW
- Net Weight: 172g
ORDER NOW
- Net Weight: 111g
ORDER NOW
