Deep floating shelves? 40cm?
18 Mar 2015
Does anyone know where I can get some floating shelves in a veneered oak effect around 60CM X 40CM? I'm struggling to find much over 20-30CM. Ideally not wanting to go bespoke, due to the sheer cost of them
my guess is that they dont make them that deep due to the leverage effect on the end furthest from the wall, and therefore how strong they would have to make the brackets to cope (and assuming it doesnt just rip them out of the wall)
I've made deep floating shelves before. I used some steel bars. Drilled a hole into the wall, used resin to fix the steel and then slotted on the shelf which had holes drilled to match the location and diameter of steel.
If that makes no sense watch this:
