putting together a list of the final components for my budget gamer build
looking at the zalman z3 plus(lots of fans and good price tag) and the Deepcool Lucifer but the question is,is the case gonna house that cooler?
cheers
grolly
I have an unused Deepcool Lucifer sat here in it's box because looking at the measurements slipped my mind when ordering all the bits for a new build. It was a few mm too tall for the case. I'm now using an Alpenfohn Matterhorn that fits and does the job .
The Lucifer cooler does seem to be a brilliant cooler for the price according to the reviews.
Couldn't find any info on max cpu cooler size but what I did find out is that there is only 10mm clearance behind the mobo tray so cable managment will be awful.
right i have answered my own question
and the answer is NO,max of 160mm grrrr
so im off too the cooling and overclocking section for some advice on my options.
cheers guys
grolly
Same max cooler height as my case (Raijintek Agos). The Matterhorn Pure cooler should fit fine as it's what I'm now using . The box to my case also says it will fit the Raijintek Ereboss cooler which is £29.99 at OcUK.
EDIT: Actually my case with it's limited 160mm cooler height will fit all Rainjintek coolers except for the Nemesis (reading from the box). So they should fit yours too .
