Default source when turning on TV/AV Receiver
25 Jul 2010
Worcestershire
Kit list
Denon X2000
Samsung 48H6400
Sky+HD
Bluray player
When I turn on my TV using the TV's remote, it handily also turns on the AV Receiver via HDMI-CEC (I think).
Before I moved house, when I did this the default source would be CBL/SAT (which is the HDMI input that I have the Sky+HD box plugged into) and this worked well as this is what we use the TV for 80% of the time.
Since moving, this is no longer the case. When I turn the TV and Sky box on, the receiver outputs the Sky Audio and Video for about 5 seconds before reverting to "TV Audio", showing a blank screen and no sound (as the TV itself isn't doing anything at this point). This is very annoying, especially as I have to open a cupboard door to use the receiver remote to switch it back to CBL/SAT every time I turn it on.
It never used to be a problem before, but I can't find any menu option whatsoever that will help. Does anyone know why this happens and how to fix it?
A harmony remote would probably sort it all but I don't really want to drop the money on it.
Anything in this thread help, after the first post they start referring specifically to Denon Amps.
http://www.avsforum.com/forum/90-re...automatically-switches-receiver-tv-input.html
CEC is great when it works but and absolute arse when it starts trying to be "clever", I ended up going down the Harmony hub route and will not look back now even if it means I have to use an optical from TV to Amp as ARC will not work without CEC.
