Define 7 mini case Sapphire Nitro or Pulse for space
9 Jul 2017
Hi, im stuck on which new graphics card to get.
Current pc is 7800X3D on a msi micro atx board in a Define 7 mini case. I have a 240mm aio radiator in the top and the stock front(140mm) and rear fan
Im wondering what new graphics card to get, current one is really old.
So do i get the 7800xt nitro long version at 320mm which should fit with no front fan or the fan moved up, or do i get a 7800xt pulse at 280mm.
Max card size is 331mm with no fan or 306 mm with a front 25mm fan for the case.
I dont really want to make the rear an intake as that has no dust filter, if I remove the front fan I have no intake fan at all, 320mm looks really tight but the nitro version isnt much more than the pulse in money terms and id imagine its quieter with 3 fans.
Or if someone wants to suggest another card budge around £400
I wont be overclocking
Thanks for the help.
The Nitro versions are usually nice cards, but I wouldn't cry about a Pulse, they're generally pretty solid.
