- 8 Mar 2011
- London
Hi all,
I'm considering getting a Fractal Design R3 Silver Arrow (McLaren all the way!
The only thing I’m not sure about having changed my mind from a full tower BitFenix Venom (other than fitting my 6950 into it, although I’m pretty sure it will!) is the airflow.
The R3 only comes with two 120mm fans but has the option for 4 more
1x extra front
2x extra top
1x extra bottom
I wouldn’t want (for noise reasons) and can’t afford more than two extra fans and I wondered if anyone could explain a logical hierarchy for adding extra fans into the case.
i.e. ‘Add a top one first because of X, and then a bottom one because of Y etc etc.’
Also should I go for more Fractal fans or are there better/quieter/cheaper fans that I should consider instead?
Thanks for your help
1x extra front
2x extra top
1x extra bottom
