Define R5- lost HDD rubber mounts, where can i get more.
27 Dec 2008
As in the title iv lost my HDD rubber mounts since i got the case 4 years ago and now, need them now as I am going to reuse the case for a server. wondering where i can get more of them or if there is an alternative that i can use.
You'll probably end having to contact Fractal anyway, but presumably these are what you're after.
https://www.fractal-design-shop.de/HDD-Mounting-Kit
Alternatively you can google for anti-vibration hdd screws, take a gamble on some cheap packs and see if any fit, there are a few packs that are similar in design that might work.
