I'm putting off Zalmanising my 7900GT because of the known issue with reliability. I can tolerate the stock Leadtek cooler. It's not horribly loud for a stock cooler and the pitch of the noise is a good one. I'd prefer it quieter and cooler (GPU temp nudges into the high 60s under load in this weather), hence the Zalman.
But...I don't want to put a Zalman on it and later find out that it's one of the delayed failure specials.
I've run 3dMark2006 for the Deep Freeze test, but what I really want is something I can leave running for a few hours and you can't loop just the Deep Freeze test.
Is there a better option than downloading a 600MB BF2 demo and looping a benchmark on that (if such a thing is possible anyway)?
) but how easy is it to tell that you have the Infineon memory (i.e. is it branded on the card or box? or did you just call up the retailer prior to making the purchase?)
