Defrag your SAN?
26 Nov 2002
Romford
Do you defrag your SAN?
I've never bothered, mainly because my old manager said it wasnt needed. Now he's gone and I'm in charge, Im wondering if I should bother?
It depends on what is on the SAN, what file system it uses and what software you are defragging? I guess you have your SAN connected to an MS machine?
It depends on the SAN tech being used. NetApp filers use a WAFL layout, so there is no need to defrag them.
It's a good way of making senior management think you need new storage. Just run a defrag and watch the performance drop :)
On a serious note the majority of disk controllers won't have much of a problem with this. Fragmentation hits performance on a single disk in a PC a lot more than it would across multiple spindles in an array on a SAN and has already been said some disk controllers just don't have the problem.
All depends on the file system. Generally fragmentation raises seek time significantly so it is advisable but depends on vendor and proprietary FS's.
