Defragmentation Solution for Win7 (Big files)
9 Dec 2006
@ManCave
Now, normally i wouldnt use anything but Win7 Defragmentation soloution however, lately i been working with big video files a lot.
as win7 defragmentation tool only defrags files less than 64mb (i think)
is there a better solution just to check how bad my volume is & fix the big file areas that could be affected?
The Windows 7 defrag ignores chunks bigger than 64mb, not files.
If you are worried about large video files being broken up you could try moving them to a freshly formatted partition - if you have the space to hold them elsewhere of course.
Though Defraggler may be simpler. But again, it shouldn't even matter since you wont gain any performance.
