Dehumidifier suggestions?
Man of Honour
17 Feb 2003
Chelmsford
Two of our front upstairs rooms are a prone to back mould around the window so I was thinking of buying a Dehumidifier. Can anyone recommend one?
This one comes recommended apparently.
http://www.amazon.co.uk/gp/product/...ASIN=B00474K8SY&linkCode=as2&tag=fixmyroof-21
Will these only take access moisture from the air.. Apparently, I just as unhealthy to have too little moisture as it does to have too much.
Should I think about traps before buying?
http://www.homebase.co.uk/en/homebaseuk/unibond-aero-360-moisture-absorber-244912
thanks
I have to one from Amazon, well the classic one with extra controls. But its brilliant, keep the whole house (3 bed semi) at approx 60% pretty efficient as well. Helps with heating as well, blows out warm air. No more steamy windows and the bathroom is dry within a couple of hours.
might be an idea to look into why you are getting damp there. always better to treat the cause than the symptom.
