deletecommand problem
Don
5 Oct 2005
Liverpool
I have this...
<form id="form1" runat="server">
<div>
<asp:GridView ID="AdminGridView" runat="server" AutoGenerateColumns="False" BackColor="White" BorderColor="#999999" BorderStyle="Solid" BorderWidth="1px" CellPadding="3" ForeColor="Black" GridLines="Vertical" DataSourceID="EventDataSource">
<Columns>
<asp:BoundField DataField="PriKey" HeaderText="ID No" />
<asp:BoundField DataField="Typage" HeaderText="Type" />
<asp:BoundField DataField="UserName" HeaderText="UserName" />
<asp:BoundField DataField="BookedFrom" HeaderText="From" />
<asp:BoundField DataField="BookedUntill" HeaderText="Untill" />
<asp:BoundField DataField="Setup" HeaderText="Set Up?" />
<asp:BoundField DataField="TimeStamp" HeaderText="Time Stamp" />
<asp:BoundField DataField="Approved" HeaderText="Approved?" />
<asp:BoundField DataField="ModelNo" HeaderText="Model No" />
<asp:BoundField DataField="Projector" HeaderText="Projector" />
<asp:BoundField DataField="Status" HeaderText="Status" />
<asp:BoundField DataField="AssignedBy" HeaderText="AssignedBy" />
<asp:BoundField DataField="BookedIn" HeaderText="Booked In" />
<asp:CommandField ShowEditButton="True" />
<asp:CommandField ShowDeleteButton ="True" />
</Columns>
<FooterStyle BackColor="#CCCCCC" />
<SelectedRowStyle BackColor="#000099" Font-Bold="True" ForeColor="White" />
<PagerStyle BackColor="#999999" ForeColor="Black" HorizontalAlign="Center" />
<HeaderStyle BackColor="Black" Font-Bold="True" ForeColor="White" />
<AlternatingRowStyle BackColor="#CCCCCC" />
</asp:GridView>
<asp:SqlDataSource ID="EventDataSource" runat="server" ConnectionString="<%$ appsettings:ConnectionString %>"
SelectCommand="SELECT * FROM [book]" DeleteCommand="DELETE FROM [book] WHERE ([PriKey] = @PriKey)" InsertCommand="INSERT INTO [Events] ([PriKey], [Typage], [Username], [BookedFrom], [BookedUntill], [SetUp], [TimeStamp], [Approved], [ModelNo], [Projector], [Status], [AssignedBy], [BookedIn]) VALUES (@PriKey, @Typage, @username, @BookedFrom, @BookedUntill, @SetUp, @Approved, @ModelNo, @Projector, @Status, @AssignedBy, @BookedIn)" UpdateCommand="UPDATE [book] SET [PriKey] = @PriKey, [Typage] = @Typage, [Username] = @username, [BookedFrom] = @BookedFrom, [BookedUntill] = @BookedUntill, [SetUp] = @SetUp, [TimeStamp] = @TimeStamp, [Approved] = @Approved, [ModelNo] = @ModelNo, [Projector] = @Projector, [Status] = @Status, [AssignedBy] = @AssignedBy, [BookedIn] = @BookedIn WHERE [PriKey] = @PriKey">
<DeleteParameters>
<asp:Parameter Name="PriKey" Type="Int32" />
</DeleteParameters>
<UpdateParameters>
<asp:Parameter Name="Typage" Type="String" />
<asp:Parameter Name="Username" Type="String" />
<asp:Parameter Name="BookedFrom" Type="String" />
<asp:Parameter Name="BookedUntill" Type="String" />
<asp:Parameter Name="SetUp" Type="String" />
<asp:Parameter Name="TimeStamp" Type="String" />
<asp:Parameter Name="Approved" Type="String" />
<asp:Parameter Name="ModelNo" Type="String" />
<asp:Parameter Name="Projector" Type="String" />
<asp:Parameter Name="Status" Type="String" />
<asp:Parameter Name="AssignedBy" Type="String" />
<asp:Parameter Name="BookedIn" Type="String" />
</UpdateParameters>
<InsertParameters>
</InsertParameters>
</asp:SqlDataSource>
</div>
</form>
and its not deleting throwing this up...
Must declare the scalar variable "@PriKey".
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: Must declare the scalar variable "@PriKey".
Source Error:
cheers in advance
Stelly
Might want to declare you parameters before you declare your SELECT, UPDATE, INSERT and DELETE commands.
TrUz
Try this:
Code:
To
Code:
[B]DataKeyNames="PriKey"[/B]>
LOL - Ignore my previouse post. You have no SELECT parameters declared.
You need to include:
Code:
<SelectParameters>
</SelectParameters>
TrUz
Code:
<SelectParameters>
</SelectParameters>
TrUz
Even if there's no parameter needed for the select query?
He has declared a SelectCommand that has included a parameter so he does need it in this case.
EDIT: Oh no he has not, my bad.
TrUz
Is you PriKey column set to Identity? If it is then you should be be inserting or updating the primary key.
TrUz
figured it out lads... silly me
Code:
should be
Code:
<asp:GridView ID="AdminGridView" runat="server" AutoGenerateColumns="False" BackColor="White" BorderColor="#999999" BorderStyle="Solid" BorderWidth="1px" CellPadding="3" ForeColor="Black" GridLines="Vertical" DataSourceID="EventDataSource" DataKeyNames="PriKey">
Mr B Gates said:
Gets or sets an array that contains the names of the primary key fields for the items displayed in a GridView control
need to set the primarykey in the gridview... oops!
Thanks anyway :)
Stelly
