DELETED_142147
How's this?
YOUR BASKET
1 x Gigabyte GeForce GTX 750Ti WindForce OC 2048MB GDDR5 PCI-Express Graphics Card £119.99
1 x BitFenix Prodigy M MATX Cube Case - Midnight Black £74.95
1 x Kingston HyperX 3K SSD 120GB 2.5" SATA 6Gb/s Solid State Drive (SH103S3/120G) £67.99
1 x AMD Athlon X4 750K Black Edition 3.40GHz (Socket FM2) Trinity Quad Core Processor (AD750KWOHJBOX) £55.99
1 x Gigabyte F2A88XM-HD3 AMD A88X (Socket FM2+) DDR3 Micro ATX Motherboard £49.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £45.95
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x EVGA ACX mITX CPU cooler, Black - 92 mm £24.95
Total : £483.80 (includes shipping : ).
-The cooler is on pre-order but I couldn't resist because it's SO CUTE!
-You really don't need an i5 for a this build (as far as I can see).
-The prodigy M is the same size as the m-itx version
-SSD because SSDs are the future
-Not sure if the Seasonic will fit in the case, probably, but will let someone better informed let us know.
The 6 core is a bit overkill for a 750ti so I'd stick with the athlon 750k
You don't match the CPU with the GPU, if you can fit a significantly better CPU in the budget, go for it.
And I'd stick with the gigabyte card because MSIs QC has been a bit iffy as of late.
It's on offer :P But yes, Gigabyte is probably a better bet.
And you don't need that EVGA PSU either.
Why not? Never skimp on the power supply of all things. It can take other components with it if it dies, I'd never get a cheap one.
YOUR BASKET
1 x Intel Core i5-4440 3.10GHz (Haswell) Socket LGA1150 Processor - Retail £134.99
1 x EVGA GeForce GTX 750Ti FTW ACX 2048MB GDDR5 PCI-Express Graphics Card £131.99
1 x BitFenix Phenom MATX Cube Case - Midnight Black £74.95
1 x Gigabyte H87M-HD3 Intel H87 (Socket 1150) DDR3 Micro ATX Motherboard £64.99
1 x Western Digital Caviar Green 1TB SATA 6Gb/s 64MB Cache - OEM (WD10EZRX) **SINGLE PLATTER** HDD £49.99
Total : £502.86 (includes shipping : ).
  • Great litte processor no overclocking but still excellent performance
  • Nice simple case I have the phenom as well and it isa nice case
  • Choose the caviar green as the only part in my PC that is noisy is in fact the hard drive
YOUR BASKET
  • Choose the caviar green as the only part in my PC is in fact the hard drive
Defo defo not that EVGA, it has fan issues that affect every ACX card.
Cant say I've noticed any fan issues with mine. That said, people on the post here http://forums.evga.com/tm.aspx?m=2123961 are saying it only happens with the nvidia driver. I'm using the nvidia linux driver and I don't have widows on the machine so can't test the differences. This of course is entirely anecdotal but I don't have any noise issues under linux which may be useful as you're intending to run SteamOS.
The issue that I was referring to was that the fans are unable to drop below 43% which, apparently, is very loud. Software has not solved this issue as far as I'm aware. When did you buy yours? I'm thinking they may have quietly rolled out a rev2 with this issue solved...
I got mine pretty much a week after it was released and it's using the old bios. I don't have any noise measurement equipment but the card itself isn't unreasonably loud.
To put it in perspective, the loudest thing in my case is the stock 120mm fan on a Corsair H50. Setting a 120mm Hiper HiperFlow fan (rated at 20db) to full RPM is significantly louder than the GPU fan.
For quietness, you can't beat the Nofan CR-95 CPU cooler. You just have to put your GPU in the #3 slot. I can also recommend the Silverpower silent PSU.
